查看: 39144|回复: 3
L-Acoustics产品国外报价
发表于 2006-9-22 16:12 | 显示全部楼层 |阅读模式
L-Acoustics - LA Amplification top <br>
Itemno. Description Price in euro <br>
APSUP APSUP rear support rack kit 50.00 <br>
LA15A LA 15a 4x370W/4x380W 8/4ohm 2,150.00 <br>
LA17A LA 17a 2x430W/2x840W 8/4ohm 1,950.00 <br>
LA24A LA 24a 2x1100W/2x1400W 8/4ohm 3,000.00 <br>
LA48A LA 48a 2x1300W/2x2300W 8/4ohm 3,900.00 <br>
MCRKSUP MCRKSUPx2 rear support kit for 12U racks 26.67 <br>
L-Acoustics - PCMCIA cards top <br>
PCM 226 PCMCIA kort for XTA-DP 226 250.00 <br>
PCM 355 PCMCIA kort for BSS-FDS 355 250.00 <br>
PCM224 PCMCIA kort for XTA-DP 224 250.00 <br>
PCM366 PCMCIA kort for BSS-FDS 366 250.00 <br>
L-Acoustics - KUDO Rigging top <br>
KBUMP K-BUMP flybar for KUDO 1,200.00 <br>
KCOVX2 K-COVx2 2xcovers for KUDO 800.00 <br>
KLIFT K-LIFT liftbar for KUDO 200.00 <br>
KPLA K-PLA dolly for KUDO 200.00 <br>
KJACKx2 KJACKx2 2 stk h鴍deskruer for K-BUMP 180.00 <br>
L-Acoustics - KUDO Speaker Cables top <br>
DOS10 DOS10 8x4mm 10m for KUDO 300.00 <br>
DOS7 DOS.7 8x4mm 0,7m for Kudo 200.00 <br>
DOSFILL DOSFILL CA-COM8 - NL8 adapter 200.00 <br>
L-Acoustics - MTD / FM Processing top <br>
LLC112B-ST LLC112b-st stereo controller 1,050.00 <br>
LLC115B-2W LLC115b-2w mono controller 1,000.00 <br>
LLC115B-ST LLC115b-st stereo controller 1,050.00 <br>
LLC115FM LLC115FM mono controller 1,000.00 <br>
MTD108LLCA MTD108LLCa stereo controller 1,050.00 <br>
L-Acoustics - P-series Self-powered Systems top <br>
108P 108P Selfpowered coax 8&quot;/1&quot; 2,500.00 <br>
112P 112P Selfpowered coax 12&quot;/1,4&quot; 3,200.00 <br>
SB15P SB15P Selfpowered 15&quot; subwoofer 2,500.00 <br>
L-Acoustics - MTD / FM Systems top <br>
115FM 115FM 2-way active 15&quot;/1,4&quot; 2,150.00 <br>
MTD108A MTD108a 2-way coax 8&quot;/1&quot; 1,100.00 <br>
MTD112B MTD112b 2-way coax 12&quot;/1,4&quot; 1,500.00 <br>
MTD115B MTD115b 2-way coax 15&quot;/1,4&quot; 1,800.00 <br>
L-Acoustics - MTD / FM Rigging top <br>
ETR1 ETR1 U bracket for 1xMTD112 150.00 <br>
ETR2 ETR2 U bracket for 1xMTD115b 150.00 <br>
ETR8 ETR8 U bracket for 1xMTD108a 150.00 <br>
PION 1 PION1 single fly ring MTD 112 10.00 <br>
ETR8-2 ETR8-2 U bracket for 1xMTD108a/108P 150.00 <br>
L-Acoustics - XT Systems top <br>
112XT 112XT highpower coax 12&quot;/1,4&quot; 1,700.00 <br>
115XT 115XT highpower coax 15&quot;/1,4&quot; 2,000.00 <br>
115XTHIQ 115XT HiQ highpower coax 15&quot;/2&quot; 2,300.00 <br>
L-Acoustics - XT Rigging top <br>
CPL112XT CPL112XT coupling of 2x112XT 280.00 <br>
CPL115XT CPL115XT coupling of 2x115XT 280.00 <br>
ETR112XT ETR112XT U brackets for 112XT 300.00 <br>
ETR115XT ETR115XT U brackets for 115XT 300.00 <br>
PION2 PION2 doubl fly ring 112/115XT 10.00 <br>
XTLIFTBAR XTLIFTBAR for 112XT/115XT 150.00 <br>
L-Acoustics - ARCS System top <br>
ARCS ARCS 2-way active 15&quot;/1,4&quot; 3,700.00 <br>
L-Acoustics - ARCS Rigging top <br>
ARCBUMP ARCBUMP for vertical arraying 700.00 <br>
ARCOUPLX2 ARCOUPLx2 H-bars for 2xARCS 100.00 <br>
ARCPLA ARCPLA dolly for ARCS 150.00 <br>
ARCSCOVX2 ARCSCOVx2 covers for 2 ARCS 553.33 <br>
ARCSSTRAP ARCSTRAPx2 for vertical coupl. 50.00 <br>
BUMP3 BUMP3 flybar for ARCS 200.00 <br>
LIFTBAR LIFTBAR for 2 BUMP3 flybars 200.00 <br>
L-Acoustics - dV-DOSC System top <br>
DV-DOSC dV-DOSC 2x8&quot;/1x1,4&quot; 3,700.00 <br>
L-Acoustics - dV-DOSC Rigging top <br>
DV-2XBUMP/1XLIFTBAR DV-2xbump/1xliftbar custommade 566.67 <br>
DV-ANGLEN dV-ANGLENx4 for concave array 15.33 <br>
DV-ANGLEP1 dV-ANGLEP1x4 0-2-3,75-5,5-7,5 60.00 <br>
DV-ANGLEP2 dV-ANGLEP2x4 1-3-4,5-6,5 60.00 <br>
DV-BUMP dV-BUMP flybar for dV-DOSC 1,050.00 <br>
DV-BUMP2 dV-BUMP2 flybar for dV-DOSC 1,000.00 <br>
DV-DOWN dV-DOWN 2xflybars for dV-DOSC 800.00 <br>
DV-PIN25 dV-PIN25x6 6pcs. for 2 dV-DOSC 120.00 <br>
DV-PIN81 dV-PIN81x4 4pcs. for dV-DOSC 140.00 <br>
FLIGHT-DV Flightcase for 3xdV-DOSC 1,500.00 <br>
L-Acoustics - dV-DOSC Speaker top <br>
DO2W DO2W 2xSpeakon amppanel adapt. 160.00 <br>
DOFILL DOFILL Speakon cable adapt. 190.00 <br>
SP.7 SP.7 4x4mm Speakon/Speakon .7m 40.00 <br>
SP25 SP25 4x4mm Speakon/Speakon 25m 200.00 <br>
SP7 SP7 4x4mm Speakon/Speakon 7m 90.00 <br>
CC4FP CC4FP Speakon/Speakon adapter 10.00 <br>
L-Acoustics - V-DOSC System top <br>
V-DOSC V-DOSC 3-way active system w. dolly 9,500.00 <br>
L-Acoustics - V-DOSC Rigging top <br>
BUMP2 BUMP2 flybar for V-DOSC 2,400.00 <br>
BUMP24 BUMP24 ANGLE strap 0.75/5.5gr 50.00 <br>
BUMP25 BUMP25 ANGLE strap 2.0gr 50.00 <br>
BUMP25 I BUMP25I ANGLE strap 1.3gr 50.00 <br>
BUMP26 BUMP26 ANGLE strap 3.0gr 50.00 <br>
BUMP27 BUMP27 ANGLE strap 4.0gr 50.00 <br>
BUMPDELTA BUMPDELTA rigging for BUMP2 250.00 <br>
CHARIOT CHARIOT for 2xBUMP2 4,580.00 <br>
SPAC25 SPAC25 ANGLE spacer 2.0gr 35.07 <br>
SPAC25I APAC25I ANGLE spacer 1.3gr 35.07 <br>
SPAC26 SPAC26 ANGLE spacer 3.0gr 35.07 <br>
SPAC27 APAC27 ANGLE spacer 4.0gr 35.07 <br>
SPAC28 SPAC28 ANGLE spacer 5.5gr 35.07 <br>
L-Acoustics - V-DOSC Speaker Cables top <br>
DO.7 DO.7 8x4mm V-DOSC cable 0,7m 190.00 <br>
DO10P DO10P SUB CABLE extention 10m 265.07 <br>
DO25 DO25 Cable for V-DOSC 25m 450.00 <br>
DO7 DO7 8x4mm V-DOSC cable 7m 250.00 <br>
DOSUB DOSUB SUB CABLE for 4 subs 5m 200.00 <br>
L-Acoustics - V-DOSC Multi Cable top <br>
DOM2 DOM2 6 pair amp link 2m 220.00 <br>
DOM30 DOM30 6 pair cross link 30m 400.00 <br>
DOMF DOMF LINK BREAKOUT 6 XLR3F 200.00 <br>
DOMM DOMM LINK BREAKOUT 6xXLR3M 195.07 <br>
DOMP DOMP adapter for DOM2 & DOM30 145.07 <br>
MC28100 MC28100 28pair multikable 100m 3,900.00 <br>
L-Acoustics - V-DOSC Racks & Panels top <br>
CO24 CO24 24ch.control output panel 1,800.00 <br>
CO6 CO6 6ch. control output panel 700.00 <br>
D2WAY D2WAY COMB connector 2-way 30.00 <br>
D37T2 COMB connector subsT2 20.00 <br>
D37T3 COMB connector subsT3 20.00 <br>
D37T4 COMB connector subsT4 20.00 <br>
D3WAY D3WAY COMB connector 3-way 30.00 <br>
DSUB DSUB COMB connector for subs 30.00 <br>
MD24 MD24 multi distribution panel 1,500.00 <br>
PAD02A PADO2a amp panel for 2 racks 800.00 <br>
PADO4A PADO4a amp panel for 4 racks 950.00 <br>
PADOSEC PADOSEC mains distribut. panel 220.00 <br>
RK122A RK122a rack 12U for two amps 2,850.00 <br>
RK124A RK124a rack 12U for four amps 3,000.00 <br>
RK12U RK12U LA doctor amprack 12U 1,700.00 <br>
D2WA D2WA COMB connector 2-way 30.00 <br>
D2WB D2WB COMB connector 2-way 30.00 <br>
D2WSTEREO D2WSTEREO COMB connector 2-way Stereo 30.00 <br>
D3WA D3WA COMB connector 3-way 30.00 <br>
D3WB D3WB COMB connector 3-way 30.00 <br>
DSUBA DSUBA COMB connector for subs 30.00 <br>
DSUBB DSUBB COMB connector for subs 30.00 <br>
DSUBTK DSUBTK set of 6 COMB Connectors SUB 150.00 <br>
L-Acoustics - Subwoofer System top <br>
DV-SUB DV-SUB 3x15 subwoofer 3,100.00 <br>
DVSUBPLA dV-SUBPLA dolly for dV-SUB 150.00 <br>
MTD118 MTD118 1x18 subwoofer 2,000.00 <br>
SB115 SB115 1x15&quot; subwoofer 1,100.00 <br>
SB118 SB118 1x18&quot; subwoofer 1,850.00 <br>
SB218 SB218 2x18&quot; subwoofer 3,100.00 <br>
L-Acoustics - Subwoofer Rigging top <br>
BUMPSUB BUMPSUB flybar for SB218 1,200.00 <br>
DV-ANGLESDPX4 dV-ANGLESDPx4 4xbar for dV-SUB 120.00 <br>
DV-ANGLESDX4 dV-ANGLESDx4 4xbar for dV-SUB 90.00 <br>
DV-ANGLESSX4 dV-ANGLESSx4 4xbar for dV-SUB 40.00 <br>
SB118COVX2 SB118COVx2 2xcovers for SB118 830.00 <br>
SB118PLA SB118PLA dolly for SB118 150.00 <br>
SUBCOVX2 SUBCOVx2 2xcovers for SB218 860.00 <br>
SUBPLA SUBPLA dolly for SB218 150.00 <br>
L-Acoustics - KUDO System top <br>
KUDO KUDO 3-way active system 6,500.00 <br>
发表于 2009-4-27 23:45 | 显示全部楼层
看不懂 是人民币还是什么啊?
发表于 2009-4-27 23:50 | 显示全部楼层
L-ACOUSTICS,国内娱乐总代理,QQ:335652635
发表于 2010-11-14 00:00 | 显示全部楼层
怎么全都是英文啊
GMT+8, 2026-11-29 16:34 , Processed in 0.126270 second(s), 31 queries , Gzip On.
