查看: 3428|回复: 7
~森海塞尔 500系列G3的问题~
发表于 2012-5-25 17:25 | 显示全部楼层 |阅读模式
各位老师有哪个有森海塞尔500系列G3的说明书咧,因为本人只有G2的说明书,G3系列在里面加了一些功能,不是很了解,所以想在这里问问哪位老师有这个说明书咧~~
这个设置是什么意思呀,有哪位老师知道?   谢谢
发表于 2012-5-26 18:13 | 显示全部楼层
楼主你若能发个英文说明书上来,我可以短时间之内提供一套中文的。
 楼主| 发表于 2012-5-27 00:04 | 显示全部楼层
我也想有一份说明书哦,问题是连英文的都没有,我有的也是G2系列的使用手册~嘿嘿
发表于 2012-5-28 12:33 | 显示全部楼层
那就先给你个英文手册吧。
EW500G3_529662_0109_US_INT.part1.rar (976.56 KB, 下载次数: 433)
EW500G3_529662_0109_US_INT.part2.rar (976.56 KB, 下载次数: 446)
EW500G3_529662_0109_US_INT.part3.rar (976.56 KB, 下载次数: 439)
EW500G3_529662_0109_US_INT.part4.rar (976.56 KB, 下载次数: 432)
EW500G3_529662_0109_US_INT.part5.rar (976.56 KB, 下载次数: 417)
EW500G3_529662_0109_US_INT.part6.rar (976.56 KB, 下载次数: 436)
EW500G3_529662_0109_US_INT.part7.rar (300.59 KB, 下载次数: 385)
发表于 2012-5-28 12:39 | 显示全部楼层
你图片里的那项cable emulation,是“线缆仿真”的意思,当该接收机配合吉他无线发射机使用时,可以模仿出吉他信号线长度和分布参数(分布电容之类)对音色的影响。
发表于 2012-5-28 12:44 | 显示全部楼层
The second feature speaks to the tone freak contingent among guitarists. Some
players like the idea of a wireless system because of the untethered freedom it
offers, but are wary of making the leap because they’ve based their sound on the
tonal impact (even if it is a negative one) of a 20' unbalanced cable. For those
players, the G3 offers a simple solution: a cable emulation mode that simulates
the capacitance effect of the cable between your pickups and the amp (or effects
in your signal chain). In this way, you can use the G3 to compensate for any
tonal differences between wired and wireless setups, leaving the settings on your
guitar, amp, and effects intact, for the times when you go back to a wired setup.
Cable emulation mode has four settings, and is just one more way the G3 allows
you to shape your tone using the wireless system, rather than making you adjust
your gear to conform to the transmission technology.
 楼主| 发表于 2012-5-29 14:27 | 显示全部楼层
谢谢版主
发表于 2014-5-7 17:48 来自手机 | 显示全部楼层
楼下的接上
GMT+8, 2026-11-9 03:45 , Processed in 0.109068 second(s), 31 queries , Gzip On.
