查看: 8864|回复: 5
[分享]3M投影机控制协议
发表于 2006-1-11 20:31 | 显示全部楼层 |阅读模式
1. RS232 Setting<br># q' B) F7 X1 M
Baud rate:  9600<br>  k) p0 W1 c: ?
Parity check: None<br>) f& x" c" b9 h. |
Data bit: 8<br>  n* s* _4 V! |  s. }4 f8 [& N
Stop bit: 1<br>Minimum delay for next command: 1ms<br>/ s- O9 a# c8 V. R4 J! q
<br>" \' _4 q- Q7 B; c/ d& y
2. Control Command Structure <br>
! l- Q" c+ v$ v. c( ?# Z4 s. jThe command is structured by the Header code, command code, data code and end code. Most of the commands are structured except some for the compatibility issue with other projectors.<br>" L* L- A  ?) {4 `: |$ _
<br>3 g/ R* ^& R0 N# X; ?
Header code Command code Data code End code<br>
  D4 a( H/ a$ w: SHEX 7Eh Command Data 0Dh<br>
- l8 E; H/ m0 W) t3 g8 G4 mASCII ‘~’ Command Data CR<br>4 d  B' m; C4 i9 W9 u4 P
/ ]) `! q; t& g* `<br>
/ ]5 P2 z' u- \3. Control Sequence<br>" h- }% n3 h* H; R0 Q
The projector may send a return code after it received a command. If the command isn’t received correctly, the projector will not send the return code<br><br>
1 H: ]3 F! q8 \/ J" _, ?<br>
( y3 C- c& B% R) t) L! P1 u4. Operation Command<br>The operation commands execute the basic operation setting of this projector.<br>5 h  Y" T6 o2 _6 J, ?2 t& e$ |( c8 \8 U
Operation ASCII HEX<br>& v! E6 J8 P1 [: C. m0 b0 S
Power On ※ ~ P N CR ※ 7Eh 50h 4Eh 0Dh<br>
4 j+ V! `  N, _' jPower Off ~ P F CR 7Eh 50h 46h 0Dh<br>  r# z+ Y! F9 {0 t
Auto Image ~ A I CR 7Eh 41h 49h 0Dh<br>* p  l# W! ?0 C! V
Input Select RGB ~ S R CR 7Eh 53h 52h 0Dh<br>
8 e5 ^6 [' W, p+ G7 C/ d$ ~Input Select RGB2 ~ S G CR 7Eh 53h 47h 0Dh<br>
7 T) I! g2 P% v4 nInput Select DVI ~ S D CR 7Eh 53h 44h 0Dh<br>
. ]7 G: N9 x, XInput Select Video ~ S V CR 7Eh 53h 56h 0Dh<br>
, A0 v- m8 W6 J: `4 ?$ SInput Select S-Video ~ S S CR 7Eh 53h 53h 0Dh<br>  [* V0 v# ^0 E& l  R. E3 Z
Input Select Component ~ S Y CR 7Eh 53h 59h 0Dh<br>' T( r% W. ?  k9 H7 ~
Input Select Wireless ~ S W CR 7Eh 53h 57h 0Dh<br>2 W6 O' L; }1 n9 C+ D& {2 z# o' X
※ Power On command will not work for 1 minute after the power off command triggered.<br>, ^* ~! U$ Q! F9 g. r
※ CR : Carriage Return. <br>" d+ c! e5 L8 I1 a2 Z
% Z' `! S, |3 W" j. r  }! {! k1 @5. Remote Command<br>
( B  R) Q# p5 u9 N  zThe remote commands simulate the code send from IR remote handset.<br>" f. A& I# T0 N( P6 ?
Button’s name ASCII HEX<br>8 X8 q5 M% J' ]1 f
UP arrow ~ r U CR 7Eh 72h 55h 0Dh<br>, l% N9 [. d0 ]; A" o
DOWN arrow ~ r D CR 7Eh 72h 44h 0Dh<br>
6 A% E6 C! c1 w; i& kLEFT arrow ~ r L CR 7Eh 72h 4Ch 0Dh<br>
) n/ [- i0 v& i* |7 c( zRIGHT arrow ~ r R CR 7Eh 72h 52h 0Dh<br>) Q; {5 A2 l8 M! M' R
POWER ~ r P CR 7Eh 72h 50h 0Dh<br>
5 E% g, S3 w2 F/ @3 ?EXIT ~ r E CR 7Eh 72h 45h 0Dh<br>
5 }, P6 X' }8 ]" x+ ]0 \INPUT ~ r I CR 7Eh 72h 49h 0Dh<br>
$ f3 B2 [: Z+ Q! OAUTO ~ r A CR 7Eh 72h 41h 0Dh<br>& N8 J1 m8 W! i& K/ R+ x
KEYSTONE+ ~ r K CR 7Eh 72h 4Bh 0Dh<br>
* q  i0 u: `0 O# ^4 N1 HKEYSTONE- ~ r J CR 7Eh 72h 4Ah 0Dh<br>
- ~! X- d$ r8 U& F0 AMENU ~ r M CR 7Eh 72h 4Dh 0Dh<br>
( }' Q+ u, ~* h( F( c) \- bSTATUS ~ r S CR 7Eh 72h 53h 0Dh<br>
$ b) e/ F- E, L: H  S+ H; QMUTE ~ r T CR 7Eh 72h 54h 0Dh<br>
7 V6 W+ B- r1 W0 PZOOM+ ~ r Z CR 7Eh 72h 5Ah 0Dh<br>, w$ K2 Q: i9 V' e! v7 p
ZOOM- ~ r Y CR 7Eh 72h 59h 0Dh<br>7 e1 E# q7 B5 `! n4 y
BLANK ~ r B CR 7Eh 72h 42h 0Dh<br># R& n9 w6 h0 ]3 u7 E/ {
FREEZE ~ r F CR 7Eh 72h 46h 0Dh<br>% g. r2 \: B/ \. _! D7 v
VOLUME+ ~ r V CR 7Eh 72h 56h 0Dh<br>
8 S# w$ ?- b' z9 Y  ZVOLUME- ~ r W CR 7Eh 72h 57h 0Dh<br>: K# N. R* o; g% W5 X1 y2 e3 l  {' B! p
Enter ~ r N CR 7Eh 72h 4Eh 0Dh<br>
: `- {5 d. g. O$ ^<br>2 a8 j$ |% S: l
6. Set Value Command<br>
4 Z' ~' J6 P7 n) x! qITEM ASCII HEX<br>
; S6 u+ \6 |. yBrightness ~ s B ? CR ※ 7Eh 73h 42h ?h 0Dh<br>) y. `1 z" d2 h- W3 u" v3 k
Contrast ~ s C ? CR 7Eh 73h 43h ?h 0Dh<br>( M- a: o" m6 @$ |) `" G9 l& ^3 Z
Color ~ s R ? CR 7Eh 73h 52h ?h 0Dh<br>2 Z4 e( l' `/ d3 c" C* e2 |) u4 V
Tint ~ s N ? CR 7Eh 73h 4Eh ?h 0Dh<br>/ m0 c  |, T7 X. j- {3 F. d# Z
Scaling ~ s A ? CR 7Eh 73h 41h ?h 0Dh<br># V! F( E( z& E
Color Temperature ~ s T ? CR 7Eh 73h 54h ?h 0Dh<br>
0 |8 c# J% ]+ x2 U0 T/ iProjection Mode ~ s J ? CR 7Eh 73h 4Ah ?h 0Dh<br>
4 H* v( R( s/ j* s# B4 z※ ? : ASCII Data <br>
$ x* ~2 B9 i: E. a0 i0 V# S: e<br>
' o5 v: I* x7 @' f3 v$ aData Range<br>
# {* ~0 [8 P1 y! J" BITEM Set Data Range Source<br>
/ W7 a' u  P. j4 ~) h/ S0 Z7 VBrightness 0 ~ 127 RGB<br>' |' p2 p4 p5 U& g! D
0 ~ 200 Video<br>
2 o2 Q, n& X* V+ b4 KContrast 0 ~ 200 RGB / Video<br>( E8 \4 s( G; C1 [$ A
Color 0 ~ 200 Video<br>
: C6 v. b6 e( G: p8 v2 z9 gTint 0 ~ 200 Video<br>- y5 }; `4 V1 b4 j3 f
Scaling 0: 4:3 1: 16:9  RGB / Video<br># |% i8 |# |) l9 r$ ~0 |3 n7 e
Color Temperature 0:Cool 1:Normal 2:Warm 3:User RGB / Video<br>9 \" y5 d$ |6 n$ l# P
Projection Mode 0:Front 1:Rear+Ceiling 2:Rear 3:Ceiling RGB / Video<br>
$ d! W" r/ {: A2 i3 ]0 T$ N<br>! U5 ~7 a. C$ I2 G# _
Attention: Data range may be different for different models<br>5 U- N$ [  J+ ^. \+ M- j4 \$ B
* w1 E6 P' x" Y+ \" q# }0 ]Example 1. Adjust Brightness value to 100<br>Send Command : ~sB100CR<br>
1 }1 q& k/ W7 ~( L' n" j<br>3 ~( @! v; W8 S: o7 G, z
Example 2. Adjust Color Temperature to Warm<br>Send Command : ~sT2CR<br>
# r8 s3 w3 j) U<br>
9 z# V) I* N" w# ?( e7. Query Command<br>' g4 V$ k) s/ k! g, k# E
ITEM ASCII HEX<br>
( v3 m- A& |) `4 K/ J) Q# a1 MSoftware Version ~ q V CR 7Eh 71h 56h 0Dh<br>0 j4 t; l0 P) P7 X7 ~
Power State ~ q P CR 7Eh 71h 50h 0Dh<br>. g: ^8 g+ |) H2 J9 P; S  a
Input Select ~ q S CR 7Eh 71h 53h 0Dh<br>
4 e, K: L5 [, _) WLamp Hours ~ q L CR 7Eh 71h 4Ch 0Dh<br>  {. H1 Q- m, W
Brightness ~ q B CR 7Eh 71h 42h 0Dh<br>
3 w# W! ?1 k- |  B: C8 TContrast ~ q C CR 7Eh 71h 43h 0Dh<br>* H/ x0 r( i6 \- H
Color (Video) ~ q R CR 7Eh 71h 52h 0Dh<br>4 l' P2 v, H  j6 T0 h/ T: ], q, x0 V
Tint (Video) ~ q N CR 7Eh 71h 4Eh 0Dh<br>3 \' A" q2 L% J; h, [
Scaling ~ q A CR 7Eh 71h 41h 0Dh<br>
, N, l* E; I" ?" n1 v( ?4 NColor Temperature ~ q T CR 7Eh 71h 54h 0Dh<br>
" Q" e) p: y. i. T7 S6 `% P- ZProjection Mode ~ q J CR 7Eh 71h 4Ah 0Dh<br>
. f% ^9 v; W: y% T2 h7 e$ wResponse message<br>4 r! n2 b+ M5 h8 b! }. t
ITEM Response Message examples <br>3 W# K: p% r7 T  ~
Software Version SAA0. 23 <br>
0 i& |6 q6 {& k7 `1 APower State On Off <br>
9 P  u" c$ i# ^! s% B* v5 tInput Select RGB DVI Video S-Video DVD HDTV <br>: @4 U4 d1 F# N6 q3 ]( P
Lamp Hours 2000 <br>; L1 ~6 D; w  Z7 l2 x& g
Brightness 100 <br>
6 q& g1 o. G2 O  z( ?$ O- UContrast 100 <br>
+ v) o- K5 ?- Y0 C! d# w% VColor (Video) 100 <br>6 R* c1 l0 ^( J$ j) z1 z
Tint (Video) 100 <br>2 q, T% v7 A- y  O: }9 }
Scaling 4:3 16:9 <br>
! e/ x$ A! V0 \/ n/ UColor Temperature Cool Normal Warm User <br>
* T5 B  g+ E. G. i# N9 V5 NProjection Mode Front Rear+Ceiling Rear Ceiling <br>1 r' X9 o' F/ p. O/ d$ ?
Eric Ge 葛萌
Mobile: (86) 13370125802
Tel: (86) 10 6409-6026
Fax: (86) 10 6409-6001
//欢迎光临中国音响设计网//
发表于 2006-1-12 11:30 | 显示全部楼层
re:支持!!为三所的这位仁兄,无私的奉献...
支持!!<br>6 o/ ]" O) W( A. X; t' n
为三所的这位仁兄,无私的奉献鼓掌.
发表于 2006-3-23 17:38 | 显示全部楼层
re:下载了,学习中
下载了,学习中
发表于 2009-12-12 21:42 | 显示全部楼层
学习一下,顺便支持一个
发表于 2009-12-27 12:10 | 显示全部楼层
谢谢分分享!!!!!!!!!!!!!!!!!!!!
21
发表于 2010-8-19 15:40 | 显示全部楼层
无私奉献 不过 如果是中文的就好了
音响行业新手,希望得到大家的帮助,天天向上
GMT+8, 2026-11-17 02:47 , Processed in 0.119430 second(s), 28 queries , Gzip On.
