查看: 24690|回复: 12
SONY(索尼)——EVI-D30/D30P/D70/D70P/D100/D100P (RS-232/422指令集)
发表于 2006-1-19 15:47 | 显示全部楼层 |阅读模式
波特率:9600/38400-N-8-1 (请注意设备底部设置拨位开关)<br><IMG onmouseover="javascript:if(this.width>520)this.width=520;" src="leadbbsfile/fileType/jpg.gif" onload="javascript:if(this.width>520)this.width=520;" align=absmiddle border=0>此主题相关图片<br>1 z* @: z# F0 T) h# v
<IMG onmouseover="javascript:if(this.width>520)this.width=520;" style="CURSOR: hand" onclick=javascript:window.open(this.src); src="leadbbsfile/upload/2006/01/19/154622.jpg" onload="javascript:if(this.width>520)this.width=520;" align=absmiddle border=0><br>$ f5 E4 z6 B0 X% y' H: o: v7 G# P
<br><br>
/ ?1 K" ^% f' O" l: Q" v$ _<br><br>: M, _! R8 K8 K" F6 Z3 @7 j, D, i
主要功能控制代码一览表: <br>
7 F0 v$ D/ V: f8 s6 i类别 功能 代码 说明 <br>
! y4 d8 L5 s2 q6 m! Y( ePower(电源) On(开) 8x 01 04 00 02 FF   <br>; [4 c( ]+ X" B; t6 O: e  |8 @& c
Off(待机) 8x 01 04 00 03 FF   <br>
9 i  C8 Q4 t3 N& S& w2 W' p4 TZoom(缩放) <br>0 M  W; {* I$ j; n
 <br>Stop 8x 01 04 07 00 FF   <br>& G; C. m1 K  x' Q* {9 T
Tele (Standard) 8x 01 04 07 02 FF   <br>' g* |" E6 E% W- ^" E( r
Wide (Standard) 8x 01 04 07 03 FF   <br>
" ?* v  p) F" z$ [Tele (Variable) 8x 01 04 07 2p FF p = 0 (Low) to 7 (High), 8 steps <br>4 c/ A/ E5 c+ i( U2 ]6 a7 P
Wide (Variable) 8x 01 04 07 3p FF <br>
) \8 `' P- l+ o% B1 N! NFocus(焦距) <br>2 R# Y3 J8 O4 H* H( P
 <br>Stop 8x 01 04 08 00 FF   <br>
1 H1 h, b; @  zFar (Standard) 8x 01 04 08 02 FF   <br>! V" l0 \1 b; y8 _6 h3 g
Near (Standard) 8x 01 04 08 03 FF   <br>, ?+ t2 [! h' U
Far (Variable) 8x 01 04 08 2p FF p = 0 (Low) to 7 (High), 8 steps <br>. }( b4 f2 j$ `! L
Near (Variable) 8x 01 04 08 3p FF <br>
0 |! U, I4 l$ K  {. KPan-tiltDrive <br>" w* c5 \" h- |2 `
Left (左) 8x 01 06 01 VV WW 01 03 FF <br>5 Q- S$ o6 r' d3 p
Right (右) 8x 01 06 01 VV WW 02 03 FF <br># M4 I" s4 D1 `# u. J4 {' h
UpLeft(左上) 8x 01 06 01 VV WW 01 01 FF <br>
+ _& @9 k, s) [UpRight(右上) 8x 01 06 01 VV WW 02 01 FF <br>/ q- L4 E. {$ ]( ~' B: h) F
DownLeft(左下) 8x 01 06 01 VV WW 01 02 FF <br>+ ?; w  n  r( |9 `. R' O
DownRight(右下) 8x 01 06 01 VV WW 02 02 FF <br>
2 b) A' `, g1 [- x% YStop(停止) 8x 01 06 01 VV WW 03 03 FF <br>- t; b: D8 u2 u: O
AbsolutePosition<br>
! x5 d% v% P6 H+ Y% t(绝对定位) 8x 01 06 02 VV WW<br>
7 i% Y. H' \. e5 V" Y0Y 0Y 0Y 0Y 0Z 0Z 0Z 0Z FF <br>
1 @, b1 d" ?) ^% u# |6 L/ \7 dRelativePosition<br>$ M' c% ]5 [# n$ k. f# L
(相对定位) 8x 01 06 03 VV WW<br>$ Q. O1 Q2 D/ ?  u& E7 u3 h
0Y 0Y 0Y 0Y 0Z 0Z 0Z 0Z FF <br>7 @/ o, a7 b1 p# ]) E
Home(初始) 8x 01 06 04 FF   <br>  ?0 V! G4 ^+ Y& r9 a4 h1 T8 A
Reset(复位) 8x 01 06 05 FF   <br><br>2 Q. l4 ^& E/ z4 C6 t! X$ y
 前8个功能需发停止代码方可停止转动 <br>
6 k5 s6 k" K; B5 F) |Down (下) 8x 01 06 01 VV WW 03 02 FF Up (上) 8x 01 06 01 VV WW 03 01 FF VV: Pan speed 01 to 18<br>
+ l  j5 q9 h* s, W4 b+ JWW: Tilt Speed 01 to 14<br>) c4 C: ?. i1 `) D
<br>$ Y' u" x3 _: d3 L2 `0 |. X9 v
YYYY: Pan Position FA60 to 05A0 (center 0000)<br>& M! d5 \& {# }; r2 Z  n: E
ZZZZ: Tilt Position FE98 to 0168 (center 0000)<br>
1 w* c/ m. u8 |, U: `5 h" ^9 `, x
发表于 2006-1-26 10:55 | 显示全部楼层
re:我用C++开发过摄像跟踪的软件,用的就是...
我用C++开发过摄像跟踪的软件,用的就是这个系列摄像机,我对他再熟悉不过了,你少了最重要的预设位的编码,这个论坛回贴好像不能加附件,否则我添加一份给大家。<br>6 i. t. ?8 r3 d+ o7 b  b' ~8 Z0 K; y
<IMG onmouseover="javascript:if(this.width>520)this.width=520;" style="CURSOR: hand" onclick=javascript:window.open(this.src); src="http://www.1000bbs.com/UploadFile/2006-1/200612610461981325.jpg" onload="javascript:if(this.width>520)this.width=520;" align=absmiddle border=0><br>
* |" A6 S7 g% e4 G& x) y6 K<A HREF="http://www.1000bbs.com/dispbbs.asp?boardid=83&id=203790&star=1#240267" TARGET=_blank>http://www.1000bbs.com/dispbbs.asp?boardid=83&id=203790&star=1#240267</A>
发表于 2006-2-21 14:06 | 显示全部楼层
re:楼主我按你的方法怎么不能控制呢是...
楼主<br>) w; g8 }: L2 ~: [( i
我按你的方法怎么不能控制呢<br>, F' f, \6 j+ P% p
是我哪里错了还是别的什么原因呢<br># v# X3 A( v" N8 d2 }! v  l% a
还有就是如果想将3台摄像头串连起来一起控制该怎么实现呢<br>
/ L8 M5 d' \& x* j  {1 [
 楼主| 发表于 2006-2-24 20:20 | 显示全部楼层
re:你用什么中控啊
你用什么中控啊
发表于 2006-2-25 16:37 | 显示全部楼层
(RS-232/422指令集)
SONY(索尼)——EVI-D30/D30P/D70/D70P/D100/D100P 我用过的,满好的效果
HAPPYBENBEN
发表于 2006-2-25 16:39 | 显示全部楼层
(RS-232/422指令集)
SONY(索尼)——EVI-D30/D30P/D70/D70P/D100/D100P 我用过的,满好的效果<img src="leadbbsfile/UBBicon/em08.GIF" width=20 height=20 align=absmiddle border=0>
HAPPYBENBEN
发表于 2006-3-16 19:28 | 显示全部楼层
re:不是很熟悉
不是很熟悉
明天不一定会更好,但更好的明天一定会到来!
发表于 2006-3-23 10:42 | 显示全部楼层
re:怎么用呀,可以说得更详细点吗?
怎么用呀,可以说得更详细点吗?
发表于 2006-3-27 14:03 | 显示全部楼层
re:现在的D70后面有串连的接口,你用422...
现在的D70后面有串连的接口,你用422方式的话,要串起来连接,不然地址不对用不了。具体的接法是第一台接主机,第二台接在第一台上,第三台接第二台上。
发表于 2009-6-24 09:38 | 显示全部楼层
不新鲜了,你可以把代码的ID地址和球机同时设置成一样,比如81/82等等。
GMT+8, 2026-12-1 02:43 , Processed in 0.161559 second(s), 37 queries , Gzip On.
