Projection Display<br>
6 z% J1 s! L% y; ]. LSerial Interface Specification<br>
' D p2 J$ \1 p! {9 k' X+ d<br>
1 C; Y; g' N3 m3 jVersion: 1.4<br>& y* _+ c' L' W3 o$ ~) ^
<br>4 q" b! `1 s$ f
<br><br>
: P5 R J% W7 d: }; `. I<br>
/ ?% M* G q! Q. p ITable of Contents<br>- i% U: I5 C. J$ Z% Y9 c; v
1. RS232 SETTING 3<br>
# W2 K3 E. s0 Q& c v2. CONTROL COMMAND STRUCTURE 3<br>
8 J7 o ^" f! F0 B3. CONTROL SEQUENCE 3<br>* Q7 J" K. }$ d* n0 H5 _7 r" @
4. OPERATION COMMAND 3<br>
q, Z6 @# J3 t$ e0 E5. REMOTE COMMAND 3<br>5 Q4 \ u9 ~8 J/ l4 ]8 ]" |; H7 o
6. SET VALUE COMMAND 3<br>/ b& B1 ^3 O7 |7 w- t$ A$ b
7. QUERY COMMAND 3<br>
" p4 r# p7 k" n* X8. HYPER TERMINAL SETTING GUIDE 3<br>
' s. |4 X. J1 M: K9 JAPPENDIX A (AMX CONTROL ROOM CONSOLE COMPATIBILITY) 3<br>
; M& q( Y8 B* |3 DAPPENDIX B (DIN TO RS232 DIAGRAM) 3<br>1 g0 A: U @" @) n- S
<br><br>
4 i4 _% C$ D! j- y5 t. G- S7 i<br>+ c' D- Q" Z, b3 g' J" V
1. RS232 Setting<br>- p( ~. Y. @ g( w, D2 q( T8 ^
Baud rate: 9600<br>. C' R* k- D% u( V! X! |
Parity check: None<br>, s9 |0 y. K/ e7 w
Data bit: 8<br>
( u. e* i3 x, q0 U w4 }Stop bit: 1<br>Minimum delay for next command: 1ms<br>
8 G9 F' \5 Z2 j8 E0 w$ @<br>& d8 ?) Y- ?8 Y* T; H; c' c
$ q8 q, V# O3 R G<br>, F, e* W3 M* u8 [
2. Control Command Structure <br>
7 U4 D3 t2 S, O1 C9 K7 pThe command is structured by the Header code, command code, data code and end code. Most of the commands are structured except some for the compatibility issue with other projectors.<br> j" r! }9 D: S% R0 [5 I0 h; e. S
<br>Header code Command code Data code End code<br>2 h3 o% T, L/ \5 k
HEX 7Eh Command Data 0Dh<br>* S) z9 U$ N: I
ASCII ‘~’ Command Data CR<br>
" X B$ J9 _5 Y; V9 D, W<br>
5 S! x! j6 e, [" u1 n3 y3 R<br>) i0 |& C& B& N, c, k7 i+ u3 e
3. Control Sequence<br>
2 t' ]( W1 T1 H& C; n( GThe projector may send a return code after it received a command. If the command isn’t received correctly, the projector will not send the return code<br><br>
1 G% K; W; g ?. L" o4 X% a<br>3 e+ z* z4 A, v6 l2 c: C' _ Z; t
4. Operation Command<br>The operation commands execute the basic operation setting of this projector.<br>
% e" e; r% g( }' ^/ \( H8 [/ OOperation ASCII HEX<br>& ]4 L& w) M) Z1 E) P& O
Power On ※ ~ P N CR ※ 7Eh 50h 4Eh 0Dh<br>/ f' S4 W& p, s8 S3 k* u
Power Off ~ P F CR 7Eh 50h 46h 0Dh<br>
% B6 \# L* a" u. uAuto Image ~ A I CR 7Eh 41h 49h 0Dh<br>' Y- H W$ O! a
Input Select RGB ~ S R CR 7Eh 53h 52h 0Dh<br>
( m& t! T' Z9 g% } BInput Select RGB2 ~ S G CR 7Eh 53h 47h 0Dh<br>0 H. I1 R5 {' f8 C
Input Select DVI ~ S D CR 7Eh 53h 44h 0Dh<br>' M; C7 @" F9 |" L
Input Select Video ~ S V CR 7Eh 53h 56h 0Dh<br>" ~) r& t, n$ y
Input Select S-Video ~ S S CR 7Eh 53h 53h 0Dh<br>; ^" ?! M. _7 P7 l7 N9 B8 I
Input Select Component ~ S Y CR 7Eh 53h 59h 0Dh<br>
& _8 l! C' J q, MInput Select Wireless ~ S W CR 7Eh 53h 57h 0Dh<br>: J5 v3 t# ` t7 W( b4 b: c) h
※ Power On command will not work for 1 minute after the power off command triggered.<br>9 Q# K, s& p, k+ |( W% N( |; ?
※ CR : Carriage Return. <br>
( E3 k% _) W/ e: ~- E<br>
4 c( E' }) f6 v. e' y5. Remote Command<br>
% t6 X! V& G, EThe remote commands simulate the code send from IR remote handset.<br>, [# h' [ d' t& c
Button’s name ASCII HEX<br>1 K4 h3 U/ j: }! A& {
UP arrow ~ r U CR 7Eh 72h 55h 0Dh<br>
" L8 F8 G# |2 S$ f+ fDOWN arrow ~ r D CR 7Eh 72h 44h 0Dh<br>
6 t/ m6 N9 I- v) XLEFT arrow ~ r L CR 7Eh 72h 4Ch 0Dh<br>
- p5 |4 C5 s$ w5 w9 d8 vRIGHT arrow ~ r R CR 7Eh 72h 52h 0Dh<br>
9 Q/ a, J j# l+ R0 hPOWER ~ r P CR 7Eh 72h 50h 0Dh<br>$ H1 Y" r* U) G6 @# ]2 Y
EXIT ~ r E CR 7Eh 72h 45h 0Dh<br>
& ^* f% \' X2 xINPUT ~ r I CR 7Eh 72h 49h 0Dh<br>+ }, d3 q. G4 j
AUTO ~ r A CR 7Eh 72h 41h 0Dh<br>+ n4 l+ F- K; t
KEYSTONE+ ~ r K CR 7Eh 72h 4Bh 0Dh<br>: E8 P7 {/ W d5 |6 b' E) A/ s
KEYSTONE- ~ r J CR 7Eh 72h 4Ah 0Dh<br>
/ ]5 X! Z" E: D0 s0 a) \1 N& L8 KMENU ~ r M CR 7Eh 72h 4Dh 0Dh<br>' N- x: x- m. m" `& l8 C
STATUS ~ r S CR 7Eh 72h 53h 0Dh<br>" k1 o; Z( f; x
MUTE ~ r T CR 7Eh 72h 54h 0Dh<br>
- h7 A" M# N7 T g5 S3 jZOOM+ ~ r Z CR 7Eh 72h 5Ah 0Dh<br>8 R# W& G4 y% G; O5 u' O
ZOOM- ~ r Y CR 7Eh 72h 59h 0Dh<br>6 i5 m5 Y; U1 I
BLANK ~ r B CR 7Eh 72h 42h 0Dh<br>
' W( c5 G, j; j K5 m+ RFREEZE ~ r F CR 7Eh 72h 46h 0Dh<br>2 b+ l z: q: d* k4 v) B: T
VOLUME+ ~ r V CR 7Eh 72h 56h 0Dh<br>
9 s6 ?( k+ ]* K6 C9 BVOLUME- ~ r W CR 7Eh 72h 57h 0Dh<br>$ @& c9 p- w, Q1 q, J2 `
Enter ~ r N CR 7Eh 72h 4Eh 0Dh<br>
7 }: L# F' g: w6 m! h0 v<br>
0 S8 @# f4 D1 ~. @5 C* l<br># ~+ p% ]" [/ S% }% ^" c7 Q
<br> E5 a5 ^+ E' X+ X( ~
<br>. n5 T H2 O! R7 a$ Y- X: Z
! W7 x2 P @* s) H) i1 @* S9 M<br>
& {5 [1 t0 F/ Y0 Z' {<br>
7 ]( `9 l: g3 Z+ \$ j" _6 X<br>
( R5 M; ]1 V# J. Z" N<br>
0 Q, x" \' @9 z2 |: G<br>
4 j( j6 T5 ^. w<br># P, e; K0 a# [* D. m2 E" T9 f
<br><br>9 k8 i3 Y: M' Q* k m
8 H7 Q. B8 f) s5 |$ `4 y3 |6. Set Value Command<br>8 w9 d; A- Y" W& H
ITEM ASCII HEX<br>
; \( S5 i3 Y3 n3 F# ^Brightness ~ s B ? CR ※ 7Eh 73h 42h ?h 0Dh<br>
, a5 G% P. y, g* XContrast ~ s C ? CR 7Eh 73h 43h ?h 0Dh<br>
( O* S1 ~# D* t9 K/ f. fColor ~ s R ? CR 7Eh 73h 52h ?h 0Dh<br>
% I& K! C; m% u% FTint ~ s N ? CR 7Eh 73h 4Eh ?h 0Dh<br>
$ y, ]$ w; t p2 y+ U4 }9 @Scaling ~ s A ? CR 7Eh 73h 41h ?h 0Dh<br> x/ U8 B5 f8 Y2 c
Color Temperature ~ s T ? CR 7Eh 73h 54h ?h 0Dh<br>! u' l# S7 S+ e4 {, l! K% O9 z! k
Projection Mode ~ s J ? CR 7Eh 73h 4Ah ?h 0Dh<br>
! K3 P2 i \& o- D※ ? : ASCII Data <br>
3 I( ]9 M5 G, l2 a- y9 r& Z<br>
1 z8 l4 n5 a' v, l( K9 xData Range<br>7 _7 J* Z- N2 t* Q5 A
ITEM Set Data Range Source<br>
& I' S4 ~3 \$ f2 c/ ?8 d8 m' BBrightness 0 ~ 127 RGB<br>0 ~ 200 Video<br>; V2 c. T h9 W# I
Contrast 0 ~ 200 RGB / Video<br>
% }! m* M5 F) n' A: aColor 0 ~ 200 Video<br>, ~, [6 O( C( S9 e$ ?& j3 W
Tint 0 ~ 200 Video<br>
3 P, E, G* w' f: IScaling 0: 4:3 1: 16:9 RGB / Video<br>
+ M# U# s, z( jColor Temperature 0:Cool 1:Normal 2:Warm 3:User RGB / Video<br>
f: n( H8 c4 q4 R, zProjection Mode 0:Front 1:Rear+Ceiling 2:Rear 3:Ceiling RGB / Video<br>* q2 I- d& ^. G7 L! L9 C# \
& P5 m; a; u& M7 m, W O, ZAttention: Data range may be different for different models<br>
" M& Z+ u1 M: |' D# B% {: A# h7 m<br>
, F. o/ _3 w1 x8 VExample 1. Adjust Brightness value to 100<br>Send Command : ~sB100CR<br>! i* k- s: r. o" V! V0 g( X
/ I5 b' \+ w5 `4 d6 uExample 2. Adjust Color Temperature to Warm<br>Send Command : ~sT2CR<br>
; M3 h: e! D; _( f; S8 p" x8 v<br>
! N# e& W, G; s- \<br>
6 Q) g, Q/ [5 Y8 w) i4 a F. p! y, ^<br>+ P9 k- m- t5 w- `: h
& G( s. I0 @ R" ]( x3 b<br><br>
2 @$ f0 M( G. ^7 N7 l# ?<br> G+ }! @$ m5 i" r
7. Query Command<br># j( c1 c6 O0 \% x: U* j7 e( S& Z
ITEM ASCII HEX<br>
" w D2 n' _% ]4 |0 SSoftware Version ~ q V CR 7Eh 71h 56h 0Dh<br>
8 ]) v( H7 ]; j* g# z( h5 }Power State ~ q P CR 7Eh 71h 50h 0Dh<br>
* D! z$ t5 Q3 I, {# Q: ZInput Select ~ q S CR 7Eh 71h 53h 0Dh<br>
6 Q3 R- P _2 F/ s# R1 ]9 P5 Z0 K, g; GLamp Hours ~ q L CR 7Eh 71h 4Ch 0Dh<br>
}+ F1 [. W+ C: D' D/ w8 [& `7 NBrightness ~ q B CR 7Eh 71h 42h 0Dh<br>% _: T( S8 j$ N0 C$ Z$ m7 y
Contrast ~ q C CR 7Eh 71h 43h 0Dh<br>
& N1 C: \( V8 l& g1 g- CColor (Video) ~ q R CR 7Eh 71h 52h 0Dh<br> J+ Q N k8 v7 u
Tint (Video) ~ q N CR 7Eh 71h 4Eh 0Dh<br>
! s2 T( A1 _- W# X& b2 Q3 HScaling ~ q A CR 7Eh 71h 41h 0Dh<br>" G( d& q& W% W/ L+ X& i
Color Temperature ~ q T CR 7Eh 71h 54h 0Dh<br>; K/ ?$ @5 a; b6 i0 H. r D
Projection Mode ~ q J CR 7Eh 71h 4Ah 0Dh<br>
* o& y; x" h4 cResponse message<br>- X( [% G6 T" K l3 i# z
ITEM Response Message examples <br>
3 s4 X2 x3 V/ Z' O3 y- b+ |Software Version SAA0. 23 <br>
6 f% A4 |- i' h9 cPower State On Off <br>+ L, n Q( @+ `( b$ A- c2 F( G( w3 f
Input Select RGB DVI Video S-Video DVD HDTV <br>
: k1 m- [. b1 y3 ^4 u% y. |, K. m, y/ aLamp Hours 2000 <br>
* |. S s: B1 W' V- \ t- xBrightness 100 <br>
. [" G; X5 g S4 F* T8 R! |0 }" b8 qContrast 100 <br>
* l% Q6 Q5 t5 XColor (Video) 100 <br>
! G- i+ Z8 x7 v) ~Tint (Video) 100 <br>
& A4 ]+ u5 s* |7 y" @2 `. h# MScaling 4:3 16:9 <br>
) w& ~) S' c5 `$ V' J" [Color Temperature Cool Normal Warm User <br>
- [2 _; f+ @) Z9 oProjection Mode Front Rear+Ceiling Rear Ceiling <br>
_( Q# h$ m* K5 C& ~0 l% ~<br> Q0 d. W# o- f; B) p8 Q
Example 1. Get Brightness value <br>Send Command : ~qBCR<br>Response : 100<br>
9 |# q! s9 K" ^ O+ {. V<br>
2 Y" f) c0 L. h/ F$ sExample 2. Get Color Temperature <br>Send Command : ~qTCR<br>Response : Warm<br><br>
& a0 K: t' y3 A9 g/ v1 v0 @4 ^<br>
; E1 [; F0 |9 z: a5 X% q5 U, c6 T8. Hyper Terminal setting guide<br>9 y; u- H6 R5 J
8-1 Connect the RS232 Cable between your computer and Projector。<br>
' ]+ K, Z* l; n% \. L2 j1 e<br>
# E& d7 `" S* ^5 y. q( n, K8-2 Open HyperTerminal ,<br>4 g4 e, u% `$ ?1 H, j r6 `0 l
Window2000/XP HyperTerminal path:<br>, z5 {$ G( O) n
Start \ Programs \ Accessories \ Communications \ HyperTerminal。<br><br>: U0 ~7 n6 g! y
<br>0 w8 q( l' P$ G7 c# c) h/ ]4 E2 H
8-3 Setting the HyperTerminal parameter:<br> d2 z" S5 I, a# B8 Z% U
Step 1. Type the connection name .<br><br>
; L8 L% ^! C; G: a: P; j1 t' T<br> V. b0 s F3 R& E( w
<br>- f* D: S# v; A ~' \
) P8 @2 w" Z+ _% y; ?9 l* T' N- t<br>' L& n) h6 f5 C& V
Step2 . Choose the COM port for your RS232 Cable connected to.<br><br>3 l! T& ^1 c( w9 u5 ?- p) D" }/ F
( j2 h' t, T7 J9 ~8 ~9 P* tStep3. In Bits per second choose “ 9600 ” and in Flow control choose “ None ”。<br><br>9 _. S4 X* r( b( U4 R
<br>: f0 h/ z; M% @+ s3 d0 ?4 ^
" M4 @9 l9 L p7 Q<br>/ d8 Y' m4 H' F0 {4 z% ~5 E
7 {) a8 y) W" @+ b6 i<br>
2 p7 @2 p+ T, J" a5 S# t UStep4. Click the File and choose Properties to setting Keyboard parameter。<br><br>/ M2 n2 x& A& ?9 |2 M3 j4 Z* J
( Y# i, [' N; n8 LStep5. In Setting page , choose Emulation type for your keyboard.<br><br>& h, G' ]5 Q! g/ `! }9 C
% l& j# W0 h. J! V$ G- v* _<br>
% i( t* \; X7 \8 p- ^<br>4 |, Z9 i+ c9 V ]" M6 G! }. l# [
<br>: |$ S s9 p- K' m/ D
Step6. Click ASCII Setting icon to setup ASCII code parameter.<br><br>
. A* J; X& O! e<br> ~& |8 c, W: G
Step7. Mark Send Line ends which line feeds and Echo typed characters locally and click OK bottom to complete setting. <br><br><br>/ A" w3 u5 z/ J; O# B. ]/ F; q6 b
Appendix A (AMX control room console compatibility)<br>8 G9 e: F: p3 t
Control room console list<br>
/ B0 E0 N3 H5 `Brand Device Baud Range Max length send Max length receive<br>
3 O1 I. M0 V/ g# @! Y2 ~: [ `AMX Axcent 300~38400 64 64<br>
2 o* ~. b1 a* o/ wAMX Axcent 2 300~38400 64 64<br>
& @, } r; L- \AMX Axcent 3 300~115200 64 64<br> H" H# j/ k0 z4 u, o, z2 g
AMX AXB-EM232 300~38400 64 64<br>/ ]$ C1 _! ~6 p
AMX AXC-232 300~38400 64 64<br>
1 D; B+ u7 F0 hAMX AXC-232++ 300~115200 64 64<br>
; f& R$ f1 G! jAMX AXB-232+ 300~38400 64 64<br>
* ]1 b! R K0 [/ YAMX AXB-232++ 300~115200 64 64<br>$ v/ W3 S% u1 t: A/ X% R
AMX AXB-PCCOM 300~38400 64 64<br>
$ s( D3 @4 s: @: {AMX NXC-COM2 150~230400 900 196<br> a4 L$ ], B% E: B& S- {! @& g% N
AMX NXI 150~230400 900 196<br>6 y, b: Q% ]; b5 l1 c. z7 {
AMX AXB-MIDI 300~38400 64 64<br>- R" X$ z! e' L
AMX AXC-MIDI 300~38400 64 64<br>
$ G1 [# L1 T5 i7 q" o% x* }AMX NXC-ME Ether Net <br>
4 ~* a4 J( z3 h2 k( M/ @/ w<br>
+ Z9 z1 Q$ X% t3 n A- Z* gPlease check the relative console provider’s website for updated product information!<br>& q v# Y) M7 S1 x4 E, a
<br><br>
( v1 T9 \. `: wAppendix B (DIN to RS232 diagram) <br>
0 b( R7 T7 E9 A2 D0 m<br><br>) _2 @- {9 V. N! R9 L
<br><br>1 C& \4 m& E* w3 z: t9 J+ i
Notes:<br>
1 L$ w( d9 V/ B8 W+ VAppendix C (DIN to RS232 diagram) <br>: @8 b* X# d. L9 R% X9 O
<br><br>
$ y- l" _( v8 V, `, y* i<br>
$ B! N3 w$ f% Q+ F( r |
