查看: 14284|回复: 24
46个品牌的返送音箱
发表于 2010-9-14 00:08 | 显示全部楼层 |阅读模式
Outline H.A.R.D. 115
Geometry: Asymmetric Vertical
System Type: Self-powered
Power: 1,000 W @ 8 Ohms
LF: 15-inch neodymium woofer
HF: 1.4-inch exit, 85 x 65 folded waveguide
Crossover: 1,250 Hz Weight: 55 lbs.
Size (H x W x D): 15.4 x 17.7 x 23.6 inches
http://www.outline.it
Electro-Voice PX1122M
Geometry: Symmetrical Horizontal
System Type: Passive or Bi-amp
Power: 600 W or 500/80 W Continuous
LF: 12-inch DVX3121 woofer
HF: dual 1-inch exit ND2 manifold, 90 x 45
Crossover: 1,400 Hz Weight: 51 lbs.
Size (H x W x D): 14.4 x 21.5 x 12 inch
http://www.electrovoice.com
Danley Sound Labs SH100M
Geometry: Fully Horn-loaded Coaxial
Power: 600 W Program
LF: 8-inch horn-loaded coaxial
HF: 1-inch exit, 110 x 110 dispersion
Crossover: 2,200 Hz Weight: 41 lbs.
Size (H x W x D): 13.6 x 21.5 x 18 inches
http://www.danleysoundlabs.com
Community M12
Geometry: Asymmetrical Horizontal, book-matched
Power: 750/160 W Program
LF: 12-inch Ferrofluid-cooled woofer
HF: 2-inch exit BMS, 70 x 40-90 asymmetric horn
Crossover: 1,500 Hz Weight: 58 lbs.
Size (H x W x D): 10.5 x 21.5 x 20.7 inches
http://www.communitypro.com
K-Array KM8
Geometry: Vertical, Horizontal Line Array
System Type: Passive, 10 Ohms
Power: 600 W AES
LF: 8-inch neodymium woofer, 3-inch v.c.
HF: dual 1.75-inch diaphragm, 100 x 20 waveguide
Crossover: 1,500 Hz Weight: 22 lbs.
Size (H x W x D): 10.2 x 11 x 13.8 inches
http://www.k-array.com
相关帖子
19
 楼主| 发表于 2010-9-14 00:11 | 显示全部楼层
O.A.P. SM-281
Geometry: Symmetrical Dual-angle
System Type: Passive 2-way
Power: 325 W Continuous
LF: dual 8-inch woofers, 2-inch v.c.
HF: 1-inch exit, 60 x 90 rotatable CD horn
Crossover: 3,200 Hz Weight: 34 lbs.
Size (H x W x D): 9.8 x 26.8 x 12.6 inches
http://www.oapaudio.com
KV2 Audio EX10
System Type: Self-powered Bi-amp
Power: 450/50 W Continuous
LF: 10-inch neodymium woofer, 3-inch v.c.
HF: 1-inch exit titanium, 100 x 80 CD horn
Crossover: 1,600 Hz Weight: 48 lbs.
Size (H x W x D): 14 x 21 x 18 inches
http://www.kv2audio.com
MacPherson M10P
Power: 200 W RMS
LF: 10-inch neodymium co-ax, 3-inch v.c.
HF: 1-inch exit, 60-degree CD horn
Crossover: 1,800 Hz Weight: 35 lbs.
Size (H x W x D): 13.4 x 19.5 x 15.2 inches
http://www.macpherson-inc.com
Meyer Sound MJF-212A
Geometry: Symmetrical Dual-woofer
Power: 3-channels, 500/500/275 W burst
LF: dual 12-inch neodymium, 4-inch v.c.
HF: 4-inch diaphragm, 50-degree CD horn
Crossover: 1,600 Hz Weight: 108 lbs.
Size (H x W x D): 16.1 x 27.1 x 23 inches
http://www.meyersound.com
Peavey QW-Monitor
Power: 1000 W or 500/100 W Continuous
LF: 15-inch ProRider woofer, 4-inch v.c.
HF: 1.6-in. exit, 60 x 60 CD horn
Crossover: 940 Hz Weight: 85 lbs.
Size (H x W x D): 17.8 x 29.8 x 21.2 inches
http://www.peavey.com
XYCAD stage 112M
Frequency Range(±3):70Hz-19.5KHz
Power: 450W AES
LF: 12-inch woofer, 3-inch v.c.
HF: 1.5-inch exit, 3-inch v.c.
Coverage(H x V):40° x 90°horm
maxium SPL:129dB cont avg ,135dB Peak
Crossover: 2,000 Hz Weight: 62 lbs.
Size (H x W x D): 15.1 x 25.1 x 13.4 inches
http://www.xycad.cn
19
 楼主| 发表于 2010-9-14 00:13 | 显示全部楼层
QSC Audio HPR122i
Power: 400/100 W class H/AB+B
HF: 1.4-inch diaphragm, 75-degree horn
Crossover: 2,000 Hz Weight: 60 lbs.
Size (H x W x D): 14.7 x 26.9 x 14.9 inches
http://www.qscaudio.com
Spectr Audio USS1
Power: 500 W RMS
LF: 10-inch woofer, 3-inch v.c.
MHF: 1-inch exit titanium, 45 x 90 horn
Crossover: 1,600 Hz Weight: 37 lbs.
Size (H x W x D): 17.5 x 21.5 x 17.5 inches
http://www.spectraudio.com
Alcons Audio VR12M
Power: 450 W RMS
LF: 12-inch neodymium cone with 3-inch v.c.
HF: 6-inch ribbon, rotatable 90 x 40 waveguide
Crossover: 1,100 Hz Weight: 39 lbs.
Size (H x W x D): 13.8 x 26.5 x 13.6 inches
http://www.alconsaudio.com
A-Line Acoustics uSonic 112
Type: Self-powered (A) or Passive (X)
Power: 1,000 W B&O ICEpower
LF: 12-inch B&C neodymium woofer
HF: 1.4-inch exit B&C, rotatable 60 x 80 horn
Crossover: 800 Hz Weight: 57/50 lbs.
Size (H x W x D): 13.5 x 28.5 x 15.5 inches
http://www.a-lineacoustics.com
Bag End Saphire
Geometry: Vertical
System Type: Passive Time-AlignTM
Power: 600 W continuous program
LF: 12-inch cone with 3-inch v.c.
HF: 3-inch diaphragm, 55 x 40 elliptical horn
Crossover: 1,900 Hz Weight: 68 lbs.
Size (H x W x D): 24 x 14 x 17.5 inches
http://www.bagend.com
19
 楼主| 发表于 2010-9-14 00:15 | 显示全部楼层
EAW MicroWedge MW12
Geometry: Coaxial 2-way
LF: 12-inch coaxial woofer
HF: 1.4-inch exit, 90 x 90 dispersion
Crossover: 950 Hz Weight: 47 lbs.
Size (H x W x D): 13.1 x 17.3 x 22.8 inches
http://www.eaw.com
Renkus-Heinz PNX121M
Power: 300 W/75 W RMS
LF: 12-inch coaxial woofer, 3.5-inch v.c.
HF: 2-inch exit, 60 x 120 CD horn
Crossover: 1,200 Hz Weight: 67 lbs.
Size (H x W x D): 14.2 x 23 x 12.4 inches
http://www.renkus-heinz.com
Coda Audio K12
Power: 500 W AES
LF: 12-inch neo. BMS with 3-inch v.c.
HF: 1-inch neo. BMS, 80 x 60 elliptical
Crossover: 1,200 Hz Weight: 35 lbs.
Size (H x W x D): 13.7 x 24.4 x 12.6 inches
http://www.codaaudio.com
Grundorf GT-1220M
Power: 350 W AES
LF: 12-inch woofer
HF: 2-inch exit, 80 x 40
Size (H x W x D): 15.2 x 23.8 x 14.8 inches
http://www.grundorf.com
PHD Professional D-112M
Geometry: Vertical
Power: 300 W Continuous
LF: 12-inch woofer
HF: 1.3-inch exit, 40 x 90 CD horn
Crossover: 2,500 Hz Weight: 44 lbs.
Size (H x W x D): 18.3 x 13.2 x 12 inches
http://www.pas-america.com
19
 楼主| 发表于 2010-9-14 00:17 | 显示全部楼层
Clair Audio 12AM
System Type: Bi-amp
Power: 300/150 W Program
LF: 12-inch cone
HF: 2-inch exit, 60 x 40 asymmetrical horn
Crossover: 1,200 Hz Weight: 74 lbs.
Size (H x W x D): 14 x 22.4 x 18 inches
http://www.clair-audio.com
Martin Audio LE1200
Power: 400 W or 400/80 W AES
LF: 12-inch neodymium, 3-inch v.c.
HF: 1.4-inch exit titanium, 60 x 60-100 horn
Crossover: 1,300 Hz Weight: 45 lbs.
Size (H x W x D): 11.5 x 23.5 x 18.5 inches
http://www.martin-audio.com
Ramsdell Pro Audio 12-CXFM
Power: 800 W or 800/150 W
LF: 12-inch coaxial woofer, 4-inch v.c.
HF: 1.5-inch exit, 70-degree
Crossover: 1400 Hz Weight: 55 lbs.
Size (H x W x D): 17.2 x 15.5 x 22 inches
http://www.ramsdellproaudio.com
Yorkville Sound TX2M
Power: 470 W Program
HF: 2-inch titanium diaphragm, 40 x 60 horn
Crossover: 1,600 Hz Weight: 58 lbs.
Size (H x W x D): 15 x 25 x 15.6 inches
http://www.yorkville.com
SLS Audio 112RM
System Type: Bi-amp, Passive option
Power: 500/60 W, 500 W AES
HF: Ribbon, 30 x 80 rotatable horn
Crossover: 1,200 Hz Weight: 70 lbs.
Size (H x W x D): 15.6 x 30 x 16 inches
http://www.slsloudspeakers.com
19
 楼主| 发表于 2010-9-14 00:19 | 显示全部楼层
Sound Bridge 7122WX
System Type: Bi-amp 3-way
Power: 600/200 W RMS
LF: 12-inch neodymium woofer
MHF: 2-inch 2-way co-ax, asymmetrical horn
Crossover: 375 Hz Weight: 49 lbs.
Size (H x W x D): 14.5 x 25.5 x 20.5 inches
http://www.soundbridge.com
Tannoy V6
Geometry: Conical
Power: 200 W RMS
LF/HF: 6-inch Dual Concentric
Crossover: Passive 1.6kHz Weight: 14.3 lbs.
Size (H x W x D): 13.15 x 9.84 x 9.25 in
http://www.tannoy.com
Tecnare V12
System Type: Passive or Self-powered
Power: 520 W RMS
LF: 12-inch neodymium woofer, 4-inch v.c.
HF: 1.5-inch exit, rotatable 60 x 80 CD horn
Crossover: 900 Hz Weight: 62 lbs.
Size (H x W x D): 15.4 x 25.2 x 15.4 inches
http://www.tecnare.com
KS Audio T4M
System Type: Bi-amp
Power: 500/120 W RMS
HF: 2-inch exit, 60-degree conical horn
Crossover: 1,000 Hz Weight: 55 lbs.
Size (H x W x D): 14 x 22 x 18 inches
http://www.ks-audio.com
Yamaha IF2115AS
Power: 350 W or 400/60 W AES
LF: 15-inc woofer, 3-inch v.c.
MHF: 1.4-inch exit, 60 x 60-100 rotatable
Crossover: 1,600 Hz Weight: 77 lbs.
Size (H x W x D): 18 x 30 x 15 inches
http://www.yamahaproaudio.com
19
 楼主| 发表于 2010-9-14 00:20 | 显示全部楼层
Adamson M15
Power: 500/140 W AES
LF: 15-inch neodymium Kevlar cone
HF: 1.5-inch B&C, 50-degree conical
Crossover: 800 Hz Weight: 56 lbs.
Size (H x W x D): 18.4 x 28.5 x 12.1 inches
http://www.adamsonproaudio.com
d&b audiotechnik M4
Power: d&b D6 or D12 processor amp
LF: 15-inch neodymium driver
HF: 1.3-inch exit, 70 x 50 rotatable horn
Crossover: 1,000 Hz Weight: 44 lbs.
Size (H x W x D): 14.2 x 22.8 x 20.5 inches
http://www.dbaudio.com
L-Acoustics 115XT HiQ
Geometry: Asymmetrical Coaxial
System Type: Bi-amp
Power: LA4 processor amp
LF: 15-inch neodymium co-ax, 3-inch v.c.
HF: 3-inch diaphragm, 50-degree CD horn
Crossover: 1,000 Hz Weight: 63 lbs.
Size (H x W x D): 14.4 x 22.8 x 17.3 inches
http://www.l-acoustics.com
Turbosound TFM 450
System Type: Bi-amp
Power: 400/100 W RMS
LF: 15-inch neodymium, 4-inch v.c.
HF: 3-inch dia. neodymium, 40 x 60 horn
Crossover: 1,300 Hz Weight: 70 lbs.
Size (H x W x D): 15.8 x 28 x 18.7 inches
http://www.turbosound.com
Nexo PS15
Power: 1,200 W/8ohms, 1,800 W/4 ohms
HF: 2-inch exit titanium, 55 x 50-100 CD horn
Crossover: 900 Hz Weight: 64 lbs.
Size (H x W x D): 17.1 x 26.3 x 14.5 inches
http://www.nexo-sa.com
19
 楼主| 发表于 2010-9-14 00:22 | 显示全部楼层
Dynacord MADRAS M15
Power: 460/140 W Continuous
LF: 15-inch EVX155
HF: 1-inch exit EV ND6, EV 80 x 55
Crossover: 800 Hz Weight: 84 lbs.
Size (H x W x D): 20.6 x 16.3 x 15.4 inches
http://www.dynacord.com
Duran AXYS UFM-112
Power: dual 210 W amps
LF: 12-inch cone
HF: 1-inch exit, 90 x 90 @ 1kHz
http://www.duran-audio.com
EONA ADR M1225HH
Power: 330/300 W burst RMS class D
LF: 12-inch neodymium coaxial woofer
HF: 1.4-inch exit neodymium driver
Crossover: 1,100 Hz Weight: 42 lbs.
Size (H x W x D): 15.3 x 20.9 x 17.6 inches
http://www.adraudio.com
WorxAudio UltraMax
Power: 500/250 W RMS
MHF: 1.4-inch exit, 70-degrees conical
Crossover: 1,600 Hz Weight: 73 lbs.
Size (H x W x D): 18 x 25 x 15 inches
http://www.worxaudio.com
FBT Verve 15M
Power: 250 W AES
LF: 15-inch B&C coaxial woofer
HF: 1-inch exit, 90-degree conical
Crossover: 1,800 Hz Weight: 22 lbs.
Size (H x W x D): 17 x 22.4 x 15 inches
http://www.fbtusa.net
19
 楼主| 发表于 2010-9-14 00:24 | 显示全部楼层
Proel EDGE 15CXPB
Power: 900 W or 900/75 W AES
LF: 15-inch coaxial woofer, 4-inch v.c.
HF: 1.5-inch exit neodymium, 65-degree CD horn
Crossover: 1,400 Hz Weight: 73 lbs.
Size (H x W x D): 15.5 x 23 x 24.3 inches
http://www.proelgroup.com
McCauley FM850
System Type: Bi-amp
Power: 1,000/220 W AES
HF: 1.4-inch exit titanium, 55 x 70 horn
Crossover: 1,350 Hz Weight: 56 lbs.
Size (H x W x D): 13.7 x 27.2 x 18.5 inches
http://www.mccauley.com
JBL Professional VRX915m
Power: 600 W or 600/75 W Continuous
LF: 15-inch 2265H Diff. DriveTM woofer
HF: 1.5-inch exit, 2452H, 90 x 50 horn
Crossover: 1,100 Hz Weight: 46 lbs.
Size (H x W x D): 17 x 24.8 x 12.8 inches
http://www.jblpro.com
PAS SM-2.2P
Power: 500/110 W class D
LF: 15-inch neodymium Kevlar coaxial
HF: 3-inch diaphragm, 2-inch exit titanium
Size (H x W x D): 21 x 17 x 15 inches
RCF TT 25SMA
Power: 500/250 W Class D
LF: 15-inch coaxial woofer, 3.5-inch v.c.
HF: 1.5-inch exit, 60-degree conical
Crossover: 1,200 Hz Weight: 44 lbs.
Size (H x W x D): 13 x 22.9 x 17 inches
http://www.rcf.it
转自http://www.prosoundweb.com/article/a_review_of_current_floor_monitors_of_every_type_and_size/
发表于 2010-9-14 17:18 | 显示全部楼层
这也太多啦。看着头疼。{:6_169:}
GMT+8, 2026-11-22 13:54 , Processed in 0.125881 second(s), 33 queries , Gzip On.
