查看: 70322|回复: 117
声场测量软件EASERA SysTune 1.2.6最新版
 火... [复制链接]
发表于 2012-5-8 18:00 | 显示全部楼层 |阅读模式
最新版得软件
SysTune - Features
SysTune is the proven real-time audio analysis software by AFMG. It was developed especially for live sound applications and for years has been setting the standard for professional real-time measurement and display of impulse responses, transfer functions and other data. Today, SysTune is widely accepted not only in pro-audio live sound but also by installed sound professionals as well as in the industry.[size=0.7em]AFMG has invested a great amount of time and effort into research and development of new approaches to audio analysis and highest-class algorithms, with the result of several patents pending for SysTune alone. Since SysTune performs these calculations with any measurement signal, even live audio, sophisticated data becomes available for situations which have been limited to investigation before: rooms with live shows and present audiences.
Due to its eight channels, SysTune additionally can perform multiple simultaneous measurements for example at different locations, providing high-quality data in abundance.
Feature Overview
8 channels with sampling rates from 8 kHz - 192 kHz
Rapid real-time measurements in both time and frequency domain
"Real-Time Deconvolution RTD" (patent pending)
Measurements with live sound signals, pink noise, sweeps or other stimuli
Integrated, specialized signal generator
Impulse responses, phase responses, transfer functions, group delay
SPL, LEQ and NC, histograms
Averaging of measurements
Calibrate to sound pressure level, voltage or current, allowing for impedance measurements
Real-time calculation of RT and STI (IEC 60268-16, R2003)
Extremely enhanced signal-to-noise ratio by the unique "SSA-Filter" (patent pending)
Helpful permanent display of coherence and IR stability
Singular "Time-Frequency-Constant TFC" window (patent pending)
Accurate, configurable real-time spectrogram
Logging of SPL, LEQ etc. according to user-selectable international regulations
Matchless "Web-Interface" for smartphones & tablets
Simulation of EQ settings with "Virtual EQ"
Novel "Delay-Analysis" for quick, well-founded determination of system delay times
Differential display of transfer functions and impulse responses
Open plug-in API for control of third-party DSPs, audio networks etc. from within SysTune
Intuitive, detailed analysis of measurement data
Storing, exporting and offline-investigation of data
"White-" and "Black Mode" for office/lab and live sound
Support of almost all common audio interfaces and drivers
Special integration with AUBION X.8 Ethernet interfaces
Operation in virtual machines e.g. "Parallels", "VM-Ware" etc.
SysTune - Requirements
SysTune is largely programmed in dedicated high-performance algorithms utilizing computer resources effectively. - The following parameters kann be seen as an appropriate basis:
Software Requirements
  • Microsoft Windows operating system (Windows 2000, XP, Vista, and Windows 7)
  • Both 32bit and 64bit systems are supported
  • Up-to-date drivers for your soundcard or audio interface
    (Microsoft Direct Sound "DirectX", Wave/MME for or or two input channels
    ASIO drivers required for more than two input channels)
Hardware Requirements
  • A computer running Microsoft Windows (see above)
  • Minimum graphics resolution of 960 x 720 pixels, XGA and higher recommended
  • Soundcard or audio interface (SysTune supports channels 1 to 8,
    SysTune Pro adds a matrix to make up to 32 channels available)
这是官网介绍
EASERA_SysTune_UserFiles_ST1EVL-P00000-002-030-SDA-021556-589862.zip (1.28 MB, 下载次数: 1167)
EASERA SysTune 1.2.6.part01.rar
2.29 MB, 下载次数: 4956
EASERA SysTune 1.2.6.part02.rar
2.29 MB, 下载次数: 3964
EASERA SysTune 1.2.6.part03.rar
2.29 MB, 下载次数: 3975
EASERA SysTune 1.2.6.part04.rar
2.29 MB, 下载次数: 4033
EASERA SysTune 1.2.6.part05.rar
2.29 MB, 下载次数: 3579
EASERA SysTune 1.2.6.part06.rar
2.29 MB, 下载次数: 3951
EASERA SysTune 1.2.6.part07.rar
2.29 MB, 下载次数: 3990
EASERA SysTune 1.2.6.part08.rar
2.29 MB, 下载次数: 9702
EASERA SysTune 1.2.6.part09.rar
2.29 MB, 下载次数: 4368
EASERA SysTune 1.2.6.part10.rar
2.29 MB, 下载次数: 3354
EASERA SysTune 1.2.6.part11.rar
2.29 MB, 下载次数: 3457
EASERA SysTune 1.2.6.part12.rar
2.29 MB, 下载次数: 4084
EASERA SysTune 1.2.6.part13.rar
51.05 KB, 下载次数: 2439
EASERA_SysTune_UserFiles_ST1EVL-P00000-002-030-SDA-021178-513612.zip
1.28 MB, 阅读权限: 20, 下载次数: 1065
坚持信念,勇往直前
 楼主| 发表于 2012-5-9 10:55 | 显示全部楼层
按装步骤:先安装主程序,再安装用户授权文件,一共两个,选一个(都是一样的),最后打开注册管理器,下载注册文件
坚持信念,勇往直前
发表于 2012-5-9 11:11 | 显示全部楼层
看看先
发表于 2012-5-9 14:01 | 显示全部楼层
楼主,谢谢了。
                                                             技术群:44977219(业务勿加)
发表于 2012-5-9 14:16 | 显示全部楼层
楼主,谢谢了。……
                                                             技术群:44977219(业务勿加)
发表于 2012-5-9 14:18 | 显示全部楼层
安装成功,注册失败,注册了个30天的试用版。
                                                             技术群:44977219(业务勿加)
发表于 2012-5-9 18:06 | 显示全部楼层
没失败,就是试用版。破解版哪有这么容易搞到。
发表于 2012-5-9 23:23 | 显示全部楼层
等有破解的再下载咧,哈
发表于 2012-5-10 00:05 | 显示全部楼层
等有破解的再下载
发表于 2012-5-10 10:54 | 显示全部楼层
革命尚未成功...
山東男孩
GMT+8, 2026-11-7 05:44 , Processed in 0.138111 second(s), 33 queries , Gzip On.
