查看: 8110|回复: 3
[注意]卖美国原装9.9成新单元和分频器
发表于 2005-9-22 01:04 | 显示全部楼层 |阅读模式
<IMG onmouseover="javascript:if(this.width>520)this.width=520;" style="CURSOR: hand" onclick=javascript:window.open(this.src); src="http://bbs.ca001.com/attachment/3_3741.jpg" onload="javascript:if(this.width>520)this.width=520;" align=absmiddle border=0><br>
<IMG onmouseover="javascript:if(this.width>520)this.width=520;" style="CURSOR: hand" onclick=javascript:window.open(this.src); src="http://bbs.ca001.com/attachment/3_3742.jpg" onload="javascript:if(this.width>520)this.width=520;" align=absmiddle border=0><br>
<IMG onmouseover="javascript:if(this.width>520)this.width=520;" style="CURSOR: hand" onclick=javascript:window.open(this.src); src="http://bbs.ca001.com/attachment/3_3740.jpg" onload="javascript:if(this.width>520)this.width=520;" align=absmiddle border=0><br>
<IMG onmouseover="javascript:if(this.width>520)this.width=520;" style="CURSOR: hand" onclick=javascript:window.open(this.src); src="http://bbs.ca001.com/attachment/3_3743.jpg" onload="javascript:if(this.width>520)this.width=520;" align=absmiddle border=0><br>
<IMG onmouseover="javascript:if(this.width>520)this.width=520;" style="CURSOR: hand" onclick=javascript:window.open(this.src); src="http://bbs.ca001.com/attachment/3_3744.jpg" onload="javascript:if(this.width>520)this.width=520;" align=absmiddle border=0><br>
<font color="red">美国原装BAG END高音单元和原装时差校正分频器</font>,识货的出个价,合适我就卖了。<br>
<font color="blue">它的高音是OEM EV 的DH-2010A</font>,最主要的是它的分频器是专利技术,你看他的分频器是密封的防止别人仿造。<br>
<IMG onmouseover="javascript:if(this.width>520)this.width=520;" style="CURSOR: hand" onclick=javascript:window.open(this.src); src="http://bbs.ca001.com/attachment/3_3750.jpg" onload="javascript:if(this.width>520)this.width=520;" align=absmiddle border=0><br>
此款单元和分频器是 BAG END TA5000-I TIME-ALIGN上的,高音和分频器是一套的。详细的参数可以看其官方网站 <a target=_blank href="http://www.bagend.com">http://www.bagend.com</a> 下面的是BAG END TA5000-I TIME-ALIGN的参数和图片。<br>
TA5000-I TIME-ALIGN<br>
APPLICATIONS:<br>
Auditorium Sound Reinforcement<br>
Church Sound Reinforcement<br>
Nightclub Applications<br>
DJ System Installation <br>
The TA5000-I is a permanent installation full range loudspeaker system offering both high fidelity and high efficiency. The Time-Aligned&#8482; studio quality sound provides detail and clarity not found in other designs. Rugged birch plywood finished with our beautiful utility black textured lacquer and a black steel grille will fit nicely into almost any application. Optional flying attachment points allow for safe and convenient rigging. <br>
SPECIFICATIONS: <br>
SYSTEM COMPONENTS <br>
ACOUSTIC AND ELECTRICAL <br>
PHYSICAL <br><br>
Enclosure:<br>
18 mm 13-ply birch plywood<br>
Low Frequency Transducer: <br>
15&quot; Cone<br>
2.5&quot; Voice coil<br>
80 oz. Magnet<br>
High Frequency Transducer:<br>
1&quot; Exit compression driver <br>
1.25&quot; Titanium diaphragm <br>
24 oz. Magnet <br>
Exponential horn<br>
Input Connectors: <br>
Cinch 142 screw terminal <br>
barrier strip<br>
Grille: <br>
16 Gauge black vinyl<br>
coated perforated steel<br>
Optional Hardware:<br>
Rigging points System type:<br>
2-way vented - 3.4 cu. ft.<br>
Impedance:<br>
8 Ohms<br>
Crossover Network:<br>
Passive Time-Align equalizer type at 1.7 kHz<br>
Time Offset Between Drivers:<br>
&lt; +/- 25 Microseconds<br>
Frequency Response:<br>
50 Hz to 19 kHz +/- 3 dB <br>
(4 pi Steradians)<br>
Sensitivity: <br>
101 dB SPL (1W @ 1m)<br>
Dispersion:<br>
90 degrees Horizontal (-6 dB) <br>
40 degrees Vertical (-6 dB)<br>
Power Handling: <br>
200 W continuous sine wave <br>
800 W instantaneous peak Finish:<br>
Black textured lacquer<br>
Dimensions:<br>
27&quot;h x 22&quot;w x 18&quot;d <br>
69 cm x 56 cm x 46 cm<br>
Trapezoidal, 8 degree taper <br>
per side<br>
Weight: <br>
75 lbs.<br>
34 kg<br>
Shipping Dimensions: <br>
21&quot; x 30&quot; x 25&quot;<br>
54 cm x 76 cm x 64 cm<br>
Shipping Weight: <br>
83 lbs.<br>
38 kg<br>
发表于 2005-9-23 18:18 | 显示全部楼层
re:多少银子?
多少银子?
 楼主| 发表于 2005-10-8 15:42 | 显示全部楼层
re:有意加我QQ聊:125356718
有意加我QQ聊:125356718
发表于 2005-10-29 02:09 | 显示全部楼层
re:说个价格~我做的一个场子里面有几对百利蘅...
说个价格~我做的一个场子里面有几对百利蘅的箱子
GMT+8, 2026-10-30 14:30 , Processed in 0.138952 second(s), 37 queries , Gzip On.
