查看: 5055|回复: 8
狗肉搜索
发表于 2009-1-9 15:19 | 显示全部楼层 |阅读模式
,今天无事浏览了ES的官方网站,我就纳闷,人家论坛上怎么没有谁对ES导入CAD的问题提出疑问呢,找啊找终于发现一个老兄问了同样的问题, 中国人是不是在退化,大家来搜搜“SU2EASE”这是Google出品的3D插件,网上破解一大堆,就是没办法下。
这是人家的问答
Hello , a this time I use bose modeler software but I want to change, I have try easera, and I have a probleme with the import DXF, I draw my models with SKETCH UP software, I make a 3D export DXF, I open the import DXF of ease and many faces are lost, all point are ok
can you tell me if this problem is normal?
this fonction is very important for me and I buy the software only is the fonction are ok
答Hi roodlphe
I would look at the SU2Ease utility from Germany. Overcomes all the problems you mention and is very reasonably priced - if you make money from modeling, it's well worth the expense.
http://www.rahe-kraft.de/cms/su2ease/这个网站进不去
thank you for your response very cool plug in
I download the try version to test it
rodolphe
Ihave buy the licence plug in , it work very fine, all the plates are create. wonderfull
The only problem is the transfert of licence with two computer.
The way to do that is special with a code generator (only one time)
An advice : buy one license by pc or to cross in the dark side of the force
发表于 2009-1-9 16:37 | 显示全部楼层
老外一样喜欢破解
93
发表于 2009-1-10 09:41 | 显示全部楼层
http://www.rahe-kraft.de 有中文地址,地址是:http://www.rahe-kraft.de/index.cn.htm,但是中文网页上没什么东西!
http://www.rahe-kraft.de/cms/su2ease/这个网站可以用其他的方法访问,但是我看了一下这个软件直找到了demo版本!
19万
发表于 2009-1-10 13:35 | 显示全部楼层
哈哈,看来破解软件在那里都流行呀
 楼主| 发表于 2009-1-10 15:35 | 显示全部楼层
老王啊,这个软件才绝,你那个 DEMO的没用,得给钱,才给你FULL的,然后在申请LIC真TM 有一套
发表于 2009-1-10 17:14 | 显示全部楼层
原帖由 毛林 于 2009-1-10 15:35 发表
被破解是早晚的事!哈哈
发表于 2009-1-10 23:31 | 显示全部楼层
原帖由 廖喇叭 于 2009-1-10 13:35 发表
哈哈,看来破解软件在那里都流行呀
这个是肯定的,免费的谁都想用啊,嘿嘿
发表于 2009-1-12 08:42 | 显示全部楼层
哈哈,看来破解软件在那里都流行呀
发表于 2009-1-12 17:25 | 显示全部楼层
哈哈,免费的不用白不用。
GMT+8, 2026-11-22 11:44 , Processed in 0.125233 second(s), 31 queries , Gzip On.
