查看: 3712|回复: 0
运放LM358品质供应,单价0.21/PCS
发表于 2011-8-31 15:25 | 显示全部楼层 |阅读模式
运放LM358品质供应,单价:0.21/PCS
概述
The X358consistsofdualindependent,high
gain internally frequency compensated operational
amplifiers which were designed specifically to operat
from a single power supply over a wide voltage range.
Operation from split power supplies is also possible
so long as the difference between the two supplies 3
voltsto32volts.
Application areas include transducer amplifier,DC
gain blocks and all the conventional OP amp circuits
which now can be easily implemented in single power
supply system.
特点
1.Internally frequency compensated for unity gain
2.Large DC voltage gain :100dB
3.Wide operating supply range(Vcc=3V~32V)
4.Input common-mode voltage includes ground
5.Large output voltage swing:From 0V to Vcc-1.5V
6.Power drain suitable for battery operation
替代型号M358,YD358,UPC358
18W音频功放tda2030a,单价:0.82/pcs
供应TDA2030A完美替代型号UTC2030A,漫步者,麦博大批量使用中!~替代型号:TDA2030A
14W音频功放TDA2030,单价0.74/pcs
供应TDA2030完美替代型号UTC2030,漫步者,麦博大批量使用中!~替代型号:TDA2030,YD2030,UTC2030
品质供应音频功放UTC2822H完美替代TDA2822,0.33/PCS
供应UTC2822H,戴尔,联想大批量使用!~替代型号:TDA2822,YD2822,CD2822
TA8227品质供应.单价0.82/PCS
供应TA8227替代型号:UTC8227,达硕,漫步者大批量使用!~替代型号:TA8227,YD8227,SJ8227
音频功放TEA2025,单价:0.55/PCS
TEA2025完美替代型号YG2025,漫步者,麦博大批量使用中!替代型号:TEA2025,D2025,YD2025
运放NJM4558,单价0.17/pcs
NJM4558完美替代型号X4558,麦博,漫步者大批量使用中!替代型号:NJM4558,YG4558,UTC4558,YD4558
品质供应音频运放YG4558,单价0.21/PCS
YG4558主要应用客户:麦博,漫步者,达硕.替代型号:NJM4558,X4558,UTC4558,YD4558
品质供应音频功放TDA2003,单价0.76/PCS
TDA2003替代型号UTC2003,惠威,山水大批量使用中,替代型号:TDA2003,CD2003,YD2003
运放LM324品质供应.单价:0.24/PCS
运放LM324完美替代型号X324,铁将军,雄兵大批量使用中,替代型号M324,UTC324,KA324,YD324
运放LM358完美替代型号X358,替代型号M358,YD358,UPC358
官网地址: www.ic-jiazhi.com
GMT+8, 2026-12-1 03:21 , Processed in 0.118526 second(s), 31 queries , Gzip On.
