查看: 3446|回复: 0
运放LM324品质供应.单价0.24/PCS
发表于 2011-9-1 15:33 | 显示全部楼层 |阅读模式
运放LM324品质供应.单价:0.24/PCS
1.DESCRIPTION
  The X324 consists of four independent, high
gain internally frequency compensated operationa
amplifiers which were designed specifically to operat
from a single power supply over a wide voltage range
    Operation from split power supplies is also possibl
so long as the difference between the two supplies 3
Volts to 32 volts.
    Application areas  include  transducer amplifier, D
gain blocks and all the conventional OP amp circuit
which now can be easily implemented in single powe
supply system.
2.FEATURES
*Internally frequency compensated for unity gain
*Large DC voltage gain :100dB
*Wide operating supply range(Vcc=3V~32V)
*Input common-mode voltage includes ground
*Large output voltage swing: From 0V to Vcc-1.5V
*Power drain suitable for battery operation
替代型号M324,UTC324,KA324,YD324
18W音频功放tda2030a,单价:0.82/pcs
供应TDA2030A完美替代型号UTC2030A,漫步者,麦博大批量使用中!~替代型号:TDA2030A
14W音频功放TDA2030,单价0.74/pcs
供应TDA2030完美替代型号UTC2030,漫步者,麦博大批量使用中!~替代型号:TDA2030,YD2030,UTC2030
品质供应音频功放UTC2822H完美替代TDA2822,0.33/PCS
供应UTC2822H,戴尔,联想大批量使用!~替代型号:TDA2822,YD2822,CD2822
TA8227品质供应.单价0.82/PCS
供应TA8227替代型号:UTC8227,达硕,漫步者大批量使用!~替代型号:TA8227,YD8227,SJ8227
音频功放TEA2025,单价:0.55/PCS
TEA2025完美替代型号YG2025,漫步者,麦博大批量使用中!替代型号:TEA2025,D2025,YD2025
运放NJM4558,单价0.17/pcs
NJM4558完美替代型号X4558,麦博,漫步者大批量使用中!替代型号:NJM4558,YG4558,UTC4558,YD4558
品质供应音频运放YG4558,单价0.21/PCS
YG4558主要应用客户:麦博,漫步者,达硕.替代型号:NJM4558,X4558,UTC4558,YD4558
品质供应音频功放TDA2003,单价0.76/PCS
TDA2003替代型号UTC2003,惠威,山水大批量使用中,替代型号:TDA2003,CD2003,YD2003
运放LM324完美替代型号X324,铁将军,雄兵大批量使用中,替代型号M324,UTC324,KA324,YD324
运放LM358品质供应,单价:0.21/PCS
运放LM358完美替代型号X358,替代型号M358,YD358,UPC358
GMT+8, 2026-12-1 03:20 , Processed in 0.121395 second(s), 31 queries , Gzip On.
