查看: 3273|回复: 0
品质供应音频功放TDA2003,单价0.76
发表于 2011-8-31 15:28 | 显示全部楼层 |阅读模式
品质供应音频功放TDA2003,单价0.76/PCS
DESCRIPTION
The UTC2003 has improved performance with the same pin configuration as the UTC2002.The additional features of UTC2002,very low number of external components, ease of assembly, space and cost saving,are maintained. The device provides a high output current capacity(up to3.5A) very low harmonic and crossover distortion.Completely safe operation is guaranteed due to protection against DC and AC short circuit between all pins and ground, thermal over-range, load dump voltage surge up to 40V and fortuitous open ground.
替代型号:TDA2003,CD2003,YD2003
18W音频功放tda2030a,单价:0.82/pcs
供应TDA2030A完美替代型号UTC2030A,漫步者,麦博大批量使用中!~替代型号:TDA2030A
14W音频功放TDA2030,单价0.74/pcs
供应TDA2030完美替代型号UTC2030,漫步者,麦博大批量使用中!~替代型号:TDA2030,YD2030,UTC2030
品质供应音频功放UTC2822H完美替代TDA2822,0.33/PCS
供应UTC2822H,戴尔,联想大批量使用!~替代型号:TDA2822,YD2822,CD2822
TA8227品质供应.单价0.82/PCS
供应TA8227替代型号:UTC8227,达硕,漫步者大批量使用!~替代型号:TA8227,YD8227,SJ8227
音频功放TEA2025,单价:0.55/PCS
TEA2025完美替代型号YG2025,漫步者,麦博大批量使用中!替代型号:TEA2025,D2025,YD2025
运放NJM4558,单价0.17/pcs
NJM4558完美替代型号X4558,麦博,漫步者大批量使用中!替代型号:NJM4558,YG4558,UTC4558,YD4558
品质供应音频运放YG4558,单价0.21/PCS
YG4558主要应用客户:麦博,漫步者,达硕.替代型号:NJM4558,X4558,UTC4558,YD4558
TDA2003替代型号UTC2003,惠威,山水大批量使用中,替代型号:TDA2003,CD2003,YD2003
运放LM324品质供应.单价:0.24/PCS
运放LM324完美替代型号X324,铁将军,雄兵大批量使用中,替代型号M324,UTC324,KA324,YD324
运放LM358品质供应,单价:0.21/PCS
运放LM358完美替代型号X358,替代型号M358,YD358,UPC358
官网地址: www.ic-jiazhi.com
GMT+8, 2026-12-1 03:28 , Processed in 0.109372 second(s), 29 queries , Gzip On.
