查看: 8676|回复: 8
有人知道SM7为什么灵敏度很低啊?
发表于 2005-9-19 11:01 | 显示全部楼层 |阅读模式
做一个演播厅,竟然发现SHURE 的SM7演播话筒灵敏度非常低,竟然还不如森海塞尔的领夹话筒,距离远了,拾音效果非常差劲,不知道什么原因,望各位指教,谢谢!
发表于 2005-9-21 14:45 | 显示全部楼层
re:1、我不知道你说的SM7是什么?SM57...
1、我不知道你说的SM7是什么?SM57还是SM87?我就当SM87吧。<br>
它的灵敏度是–52.5 dBV/Pa (2.4 mV) ——(1 Pa = 94 dB SPL)<br>
还可以啊。不过,它是近讲型的话筒,在近距离的低频会比较丰满一些。<br>
2、你对比的森海塞尔的话筒是什么型号的?
发表于 2008-1-17 08:27 | 显示全部楼层
我也有这样的问题存在,广播电台的直播室里面配置了二个SHURE  SM7话筒,经查,该话筒的指标不错,但是实际使用却不理想。灵敏度不如AKG的3300(3600)话筒,我用的是美奇1604VLZ3调音台,同样的增益,SHURE发输出电平要比AKG的少15dB的输出电平,郁闷,不知道这个SHURE是否假货,唉
我到这里来学习音响工程设计,请多多指教,谢谢!
发表于 2008-1-17 08:33 | 显示全部楼层
就是介个东东
Type Dynamic  Frequency Response 50 to 20,000 Hz
  view larger  Polar Pattern Cardioid (unidirectional)  Impedance Microphone impedance rating is 150 ohms (150 ohms actual) for connection to microphone inputs rated at 19 to 300 ohms.  Polarity Positive pressure on diaphragm produces positive voltage on pin 2 relative to pin 3.           Output Level (at 1,000 Hz) Open Circuit Voltage*: -59.0 dB (1.12 mV) *0 dB = 1 volt per Pascal  Electromagnetic Hum Sensitivity (Typical, Equivalent SPL/milliOersted) 60 Hz: 11 dB 500 Hz: 24 dB 1 kHz: 33 dB  Switches Bass rolloff and mid-range emphasis: Slotted response selector switches. See Figure 3 in User Guide for bass rolloff and mid-range emphasis (presence boost) response.  Cartridge Shock Mount Internal air-suspension shock and vibration isolator.  Microphone Connector Three-pin professional audio (XLR)  Swivel Assembly Integrated, captive nut for ease of attachment to stand, fits 5/8 in.-27 thread.  Case Dark gray enamel aluminum and steel case with dark gray foam windscreen.  Dimensions See User Guide  Net Weight 765.4 grams (1 lb, 11 oz)
A7WS WindscreenLarge Close-Talk Windscreen for SM7, SM7A, and SM7B Microphones.
RK345 Windscreen/Pop Filter for SM7BWindscreen (Pop Filter) for SM7, SM7A and SM7B Microphones
RPM106 Cartridge for SM7, SM7A and SM7BReplacement cartridge for SM7, SM7A and SM7B Microphones.
RPM602 Switch Cover PlateSwitch Cover Plate for SM7, SM7A and SM7B Microphones.
RPM604 Nut and WasherNut and Washer for SM7, SM7A and SM7B Yoke Mount.
User GuideEnglish, French, German, Italian, Spanish1870 KBPDF
Quick Links
35
发表于 2008-11-16 01:19 | 显示全部楼层
好顶哦 学学!!!!!!!!!!!!!!!!!!!!!!!
发表于 2008-11-18 15:56 | 显示全部楼层
我也发现舒尔的SM58拾音就是灵敏度非常低
发表于 2009-10-22 00:55 | 显示全部楼层
发表于 2011-6-20 08:22 | 显示全部楼层
要把灵敏度做高一些其实是很简单的问题,你的产品是表现人声的有线话筒,适合于欧美歌手(大嗓门)不失真也适合大陆摇滚歌手。灵敏度高了大嗓门一喊,听去像是音箱过载划破了,其实是话筒失真了(震膜超出了震动范围),调音台把音量降低也是失真的。灵敏度高低各有所长啊。很多歌手有自己喜欢的专用话筒就是这个原因。
发表于 2011-6-20 11:06 | 显示全部楼层
shure产品册里没有SM7啊
GMT+8, 2026-11-22 14:24 , Processed in 0.125686 second(s), 37 queries , Gzip On.
